honda accord 2002 coolant bleeder valve?
Old Jul 30, 2017 | 11:42 PM
thlong123's Avatar
Question honda accord 2002 coolant bleeder valve?
Hi,
I'm changing coolant for my car and can't find where the bleeder valve is. I would like to see if anyone know where it is. a picture would be great
Old Jul 31, 2017 | 11:17 AM
There doesn't appear to be a bleeder. See attachment. Open radiator cap and circulate for 5 mins w/ heater on full blast.
File Type: pdf
Old Jul 31, 2017 | 02:18 PM
thlong123's Avatar
I tried that and the coolant flushed out everywhere.
Old Jul 31, 2017 | 02:26 PM
thlong123's Avatar
I filled up the coolant again, drove for 15' , and check, the coolant steaming from the cap like a train
Old Aug 1, 2017 | 01:29 PM
If coolant is leaking directly from radiator cap, the cap should be replaced. If bypassing the radiator cap to the reservoir, either bad radiator cap or engine gases are entering the cooling system.
Old Aug 1, 2017 | 09:15 PM
thlong123's Avatar
That's what happened with the new cap since the old one is broken. I took a picture of the radiator where the cap is.
https://drive.google.com/file/d/0B0F...ew?usp=sharing
Do you think this is bad? Thanks
Old Aug 1, 2017 | 09:20 PM
A picture of open radiator tells nothing. I thought coolant was leaking by radiator cap?
Old Aug 1, 2017 | 09:26 PM
thlong123's Avatar
it broke inside there. So I don't know if I need to replace the radiator. (You can see that it is not a complete circle inside there.)
Old Aug 2, 2017 | 10:28 AM
It looks like the rim of the inner ring (sealing surface for pressure relief part of cap) is broken or damaged. If so, radiator will need to be replaced to recover correct cooling of vehicle.
Old Aug 2, 2017 | 11:56 AM
thlong123's Avatar
Thanks
