Honda accord 2004 4 Cylinder pick up problem
Old Oct 20, 2015 | 12:08 AM
koolguy123's Avatar
Exclamation Honda accord 2004 4 Cylinder pick up problem
Hello,
I have honda accord 2004 4 cyl , 4 door. Lately I have noticed that pick up slow down so much. I just got new tire about 4 months ago and I thought I will see better pick up but its not the case. Whenever I am going uphill, I have to turn the AC off otherwise I feel like I can walk faster than my car.
I do oil change regularly in case anyone wondering that could be an issue.
Anyone have any suggestion / ideas. Any DIY before I take it repair shop.
Old Oct 20, 2015 | 08:49 AM
joselito7's Avatar
My suggestion would be to go for an oil change with full synthetic , I usually go royal purple but mobil 1 is called for from some tuners, and change it every 4,ooo miles not what the maintenance minder states. Next I would go higher octane, again don't want the argument but I know this to work on older cars . Many will argue, don't follow the sheep try it and find out for yourself. My opinion, good luck.
Old Oct 20, 2015 | 09:22 AM
shipo's Avatar
Using premium fuel would be a mistake; stay with regular fuel and get the real problem fixed. Fact, fuel and an oil change will not fix your issues; there is something systemic which is wrong with either your engine or your transmission (more likely engine).
I'd start with having the codes read; if no codes come up, in spite of the fact I hate recommending throwing parts at a problem, changing the upstream O2 sensor (which can get lazy without throwing a code) can often cure acceleration and fuel economy issues.
Old Oct 20, 2015 | 07:28 PM
How many miles are on the car?
When were the spark plugs changed?
When was the engine air filter last changed?
Old Oct 20, 2015 | 08:41 PM
koolguy123's Avatar
Car is driven 140K miles. Spark and filter were changed last year, I would say about 9-11K miles drive since they both got changed.
Old Oct 27, 2015 | 12:16 PM
Mattc941's Avatar
Yes curious as to how synthetic oil would increase the cars peformance?
Old Oct 27, 2015 | 01:04 PM
shipo's Avatar
Simple answer; it won't.
North East
Mar 22, 2014 03:33 PM
Sig86 CM8
Oct 14, 2008 09:29 PM
academic
Jan 19, 2008 04:43 PM
y9pema
Sep 27, 2007 02:10 PM
elvis0029
Oct 23, 2005 10:10 PM
