Honda Accord 2005 Ex Coupe
Hello,
I am trying to be a do it yourself kind of person and usually google is a great help and usually takes me to this great forum. However I feel like I am not getting an answer to my question. I have a Honda Accord 2005 Ex Coup, a while back, the break switch broke off (I thought it was crayons) and the break light did not turned off, and because it was pretty dark outside when I realized what was happening, I was pulling out fuses until I found the one for the break lights. After I got the break lights fixed, now my car radio or cigarette lighter/socket does not work. I checked the fuse under the driver side, and don't know which one to check under the hood. Please help? |
It should be called aux or aux power on the label of the fuse box cover It might be called audio. I don't have my shop manual in front of me.
If you have a volt meter or a test light, there is an easy and quick way to test all the fuses. A fuse that has volts on both top tabs is good. Another invaluable tool is getting the shop manual for your car. You can get a pdf of the manual for $22 at automanualsource.com and it will pay for itself the first time you can fix a problem vs taking to a mechanic. Here is a video. |
Originally Posted by PAhonda
(Post 376908)
If you have a volt meter or a test light, there is an easy and quick way to test all the fuses. A fuse that has volts on both top tabs is good. Another invaluable tool is getting the shop manual for your car. You can get a pdf of the manual for $22 at automanualsource.com and it will pay for itself the first time you can fix a problem vs taking to a mechanic. Here is a video. https://www.youtube.com/watch?v=G07TrPjn8hI |
Check under-dash Fuse No. 32 (7.5A).
(Post 377097)
You're welcome. Good to hear things are okay now.
