honda accord 92 ex overheating replaced EVERYTHING
Old Apr 23, 2006 | 04:30 PM
  #31
copa708's Avatar
Default RE: honda accord 92 ex overheating replaced EVERYTHING
i understand that i am no good with cars right now. but i'm getting a new one so i'd like to learn how to fix this one. i know i can take it to a pro but i'd rather do it myself so i can see what's happening. i like to build or fix things and since cars are where it's at i'd like to give it a try. yah i know about the whole diagnose procedure i go with that on computers often. but still i seem to be getting mixed answers here. yah i'm about to get a manual. and by the way i just drove my car and i don't think the thermostat is opening because my lower hose is hot but not as hot as the upper hose. or maybe the fans electrical wiring is retarded... i'll figure it out soon though i just needed a pinpoint on what i need to pay attention to. thanks!
Old Apr 23, 2006 | 04:39 PM
  #32
deserthonda's Avatar
if the lower hose is HOT than your t-stat is working properly,, it is opening to allow coolant flow...........
try something real simple,,,,,,,,,,on the t-stat housing there is a green plug, start the engine, unplut that plug, jump the wires together at the plug,, if fans come on, you got a bad fan switch,, the 1 where you just disconnected that green plug from,,
try and let me know
Old Apr 23, 2006 | 04:53 PM
  #33
Hondamatic's Avatar
Copa-Sometimes it helps to just sit there and read through other's posts for a while.. do a search and get orientated with your car and the common problems people have with these. It appears that the overheating problem is common and the usual fixes are a new T-stat, or waterpump, or bad fans..
Alot of it is common sense, Like I said, do a search and see what problems others have had and how they fixed it...
https://www.hondaaccordforum.com/m_7644/tm.htm Here was a thread that I hijacked a while back [sm=innoc.gif] when I had changed my waterpump.
You can usually learn quite a bit from posts like that, and prevent multiple posts on the same topic. (in my opinion.)
Brendan.
Old Apr 23, 2006 | 04:57 PM
  #34
copa708's Avatar
how do i jump my fan switch? and by the way there isn't a green one next to the thermostat housing, there's a green one on the top radiator hose next to the engine, and also another one in between the top and bottom radiator hose. i took a paper clip and tried to jump it but i'm not sure if i'm doing it right.
Old Apr 23, 2006 | 06:05 PM
  #35
use a paper clip and jump the 2 wires togtheter at switch at thermostat housing,, i could have sworn that it was a green plug ,but maybe in the later years , anyho the 2 colr wires are ,, blue and black,, .. stick the paper clip in the plug so those 2 wires are jumped together ..on the 91 plug might be on frt side of t-stat housing. on rear of distributor
the switch next of the top rad hose is to make the fan come on when car is off.. those wires should be white/green and black... do not jump that ,,
Old Apr 23, 2006 | 06:11 PM
  #36
copa708's Avatar
i'm looking at a service manual, i do have 2 green plugs but they're infront of the engine block, not behind it where my thermostat is. but i do see the 3 plugs, 2 are green, and one's the condensor fan. which by the way that doesn't work either (fans coming on when car is off) and the grey smaller one is for the coolant temp gauge which i'm guessing is the thing in my dash, am i supposed to mess with this one or can we rule this one out? the last one is hanging off but in the picture it isn't. it's the coolant temp sensor. now ur saying i take the paper clip and touch both the prongs together with it? because i think i've tried that and nothing from the fans happens. let me see if i can find my voltimeter and test the power going to it. i switched the fuse with the window fuse by the way like in an earlier post i read and turns out my windows worked when i switched it. so i'm assuming it's not the fuse.
Old Apr 23, 2006 | 06:28 PM
  #37
copa708's Avatar
alright so the 2 green plugs i took a paper clip to both of em. i got no reaction from the fans at all.
Old Apr 23, 2006 | 06:39 PM
  #38
copa708's Avatar
what are the possibilities of this? bad wiring or a bad motor or even a bad switch? do both fans share the same motor or do they have their own one? because if they have their own one then i can probably rule out it's not the motor right?
Old Apr 23, 2006 | 06:55 PM
  #39
copa708's Avatar
i also jumped both the fans and neither came on. is it possible they both just have bad motors? like i directly jumped each one, not the switch. just the plug outside of the fans and i didn't get any response (car on or off it doesn't matter)
Old Apr 23, 2006 | 07:12 PM
  #40
Hondamatic's Avatar
The plug is green and it attaches DIRECTLY to a sensor that is on the t-stat housing. I had to jump mine back in the day when my cooling system was messed up, the fans must have ran for 8,000 miles straight (now work normally) but anyways.. It is hard to fit a paperclip in there (I know from experience ) so you will have to press it in there pretty hard, or get a smaller paperclip, I was also successful using a stripped peice of wire on both ends and jamming it in there too.
The car doesn't have to be running, just switch it to the "ON position" ( not 'ACC') so that way it's safer for you and you don't overheat the car from idling or something.
It could be different between the 91 and 92, but if you like, my neighbor has a 92 Accord LX, I can go bug him to pop his hood for me and I can take a picture of you if you need it.
B.
