Horn replacement
Old Apr 10, 2012 | 03:12 PM
AL40236173Z's Avatar
Smile Horn replacement
How do i replace the horn on my 2010 accord coupe? Any help will be much appreciated.
Thank you
Al
Old Apr 10, 2012 | 03:57 PM
Hello Al
Are you going to replace as the original is.? or are you thinking aftermarket
airhorns like I have.?
If it will be OEM..just go to Honda, buy a pair and exchange them..should be no problems except for maybe getting the PB Blaster out to soak the bolts a little before you start.
By The Way...Welcome To The HAF.
Old Apr 10, 2012 | 04:41 PM
1. Open the hood, then remove the top black plastic cover (Honda calls it a grill cover, you don't remove the grill).
On the coupe, remove the 12 plastic clips (10 of one type and 2 of another type) from cover and then pull cover out a bit, then up.
2. Disconnect the electrical connector on the horn, and then remove the one bolt holding the horn. There are 2 horns, so if you are replacing both, you would repeat the procedure for the other one.
Old Apr 10, 2012 | 10:51 PM
Thank You Red-Bull-1..good instructions you gave..Beep,Beep
khilji5
Sep 17, 2012 07:53 PM
sagdast
Dec 31, 2010 11:41 PM
lalblue
Nov 25, 2010 08:06 PM
spanishpete
Jul 25, 2006 11:36 PM
phaders
Jan 19, 2006 12:03 AM
