horrible problem
I have a 1994 Honda Accord Ex it is throwing a crankshaft position sensor code but from what i understand it is in the distributor so i replaced the distributor and it is still throwing the same code but the car also wont rev above 3500 rpms and i just can't figure out why and i dont know how to fix it does anyone no what the problem could be
RE: horrible problem
Did yourule outwiring problems (loose/dirty/corroded plugs) first?
yea i have ruled out wiring problems i honestly think but i dont know maybe computer problem or it jumped time
Yeah, check cam timing - thats not too hard to rule it out.
ECU is generally pretty robust so I tend to think of other stuff first. |
what would cause the car to throw a CKP code
Is the check engine light flashing? Limp-home mode >3500 rpm limit
have you checked the obvious? the crank position sensor? If it's unplugged the engine will not start. it may be damaged or have excessive debris on/arounf it
yes i checked the sensor and it is plugged in and when it is started the check engine light doesn't blink
There are several crankshaft position sensor errors. What specific error code do you get from the ECU.
good luck |
1994 is OBD-1 so I think theres only one CKP code (4).
