How to access and turn crank pully '92
Hi,
I need to turn the crank pully as part of adjusting my valves...but I can hardly even see the pully much less get a tool on it. Do I need to do this from below, remove some part first, or what? Neither my Chilton or Haynes manuals are any help. Thanks, Roy |
RE: How to access and turn crank pully '92
There should be an access hole in the splash guard behind the driver's front tire. You will need a 19mm deep socket to turn the crank pulley bolt. Remember to only turn it counterclockwise.
To add to the above...if you turn the wheels all the way to the left and use a long extension, it makes it easier.
I usually pull out the spark plugs to make engine rotation easy. Flat Rate Fever LOL |
Perfect. Thanks, guys.
Roy |
