How to access and turn crank pully '92
Old Dec 11, 2008 | 05:45 PM
irhunter's Avatar
Default How to access and turn crank pully '92
Hi,
I need to turn the crank pully as part of adjusting my valves...but I can hardly even see the pully much less get a tool on it.
Do I need to do this from below, remove some part first, or what? Neither my Chilton or Haynes manuals are any help.
Thanks,
Roy
Old Dec 11, 2008 | 07:53 PM
Default RE: How to access and turn crank pully '92
There should be an access hole in the splash guard behind the driver's front tire. You will need a 19mm deep socket to turn the crank pulley bolt. Remember to only turn it counterclockwise.
Old Dec 11, 2008 | 10:24 PM
hondadude's Avatar
To add to the above...if you turn the wheels all the way to the left and use a long extension, it makes it easier.
I usually pull out the spark plugs to make engine rotation easy.
Flat Rate Fever LOL
Old Dec 12, 2008 | 09:57 AM
irhunter's Avatar
Perfect. Thanks, guys.
Roy
and4rik
May 4, 2010 12:27 PM
thunder_x
Feb 12, 2007 04:38 PM
RoKnAzn
Jan 5, 2007 02:27 AM
laffinfish
Dec 27, 2006 06:12 PM
