How to reset Radio in 2003 Accord
I have the code to reset the radio. When you reset the radio does the key just have to be turned
one time, two times, or does the engine have to be running. Also to reset the code I was told to
just turn the key once and let it sit for an hour. This will reset the radio again to where it displays
"Code" on the display. Is this correct?
I tried resetting the radio with the car running and it didn't work. Any suggestions on the correct way
of entering the code in regards to the car running or just the key turned.
Thanks
Thanks
