HVAC Code 4 help
Old Sep 29, 2014 | 06:16 PM
John Mendez's Avatar
Default HVAC Code 4 help
i have DTC 4 "AN OPEN OR SHORT IN THE MODE CONTROL MOTOR CIRCUIT" it says see page 21-24. do you happen to know how to fix this or have those pages to post? thanks in advance
Old Sep 29, 2014 | 08:46 PM
I moved this to a new thread.
Do you have a volt meter to take some readings?
Old Sep 30, 2014 | 05:28 PM
I have a volt meter. Thanks in advance for the help.
Old Sep 30, 2014 | 08:21 PM
What year/trim Accord? Place in your signature for easy access.
Old Oct 1, 2014 | 12:40 PM
TX - I moved this from the end of a 7th gen thread (03-07). There is a bit of difference between the 2 and 4 door models.
Old Oct 1, 2014 | 12:48 PM
i just updated my signature. i have the 4 door.
Old Oct 1, 2014 | 01:05 PM
There are tests to run. Also be sure, if you go thru everything and are down to replacing the motor - be sure the linkage is not binding.
Attached Thumbnails HVAC Code 4 help-7th-gen-hvac-code-4-pt-1.jpg   HVAC Code 4 help-7th-gen-hvac-code-4-pt-2.jpg   HVAC Code 4 help-7th-gen-4-dr-mode-control-motor-test..jpg
Old Jul 19, 2015 | 03:45 PM
TheSilverFox's Avatar
I have an 05 Accord and the vents will not physically switch to defrost, floor, or floor/vent although the LED controls will show it switched.
The diagnostic presented the same DTC Code 4 "An open or short in the mode control circuit" mentioned above.
I am not familiar with using a volt meter and currently don't have access to one to test all the connections. Would it be a safe bet to order a new mode control motor? If so, can someone pass along the part #?
Thanks in advance.
2005 Honda Accord EX Sedan
4cyl with sunroof
Old Jul 19, 2015 | 06:49 PM
The motor is different between the 4-door and 2-door. Which one do you own?
Old Jul 19, 2015 | 06:53 PM
It is a 4 door.
