HVAC problem
The HVAC/Audio display unit was recently replaced under an extended warrantyby Honda on my '03 Accord EX V6 and now I only get cold air no matter where the temps are set. Once the A/C reaches the desired temperature it switches to cold air only from the floor vents no matter how high I set the temp controls. If it's raining the outside of the windshield fogs up and the defroster won't clear it up.
Could this be a problem with the display replacement or just coincidence? Any suggestions will be appreciated. |
RE: HVAC problem
[&:]Dixie Dog..the best I can let you in on is to go back to the dealer and have them fix the problem they created...
WheelBrokerAng ;) |
RE: HVAC problem
no idea....but i would let Honda continuously work on it til they get it right.
RE: HVAC problem
It could be a lot of things from simple mechanical (forgot to reconnect to heater core valve), improper installation, faulty part. They installed it and should fix it.
good luck |
