HVAC problem
Old Oct 3, 2008 | 08:20 PM
Dixiedog's Avatar
Default HVAC problem
The HVAC/Audio display unit was recently replaced under an extended warrantyby Honda on my '03 Accord EX V6 and now I only get cold air no matter where the temps are set. Once the A/C reaches the desired temperature it switches to cold air only from the floor vents no matter how high I set the temp controls. If it's raining the outside of the windshield fogs up and the defroster won't clear it up.
Could this be a problem with the display replacement or just coincidence? Any suggestions will be appreciated.
Old Oct 3, 2008 | 11:55 PM
Default RE: HVAC problem
[&:]Dixie Dog..the best I can let you in on is to go back to the dealer and have them fix the problem they created...
Old Oct 4, 2008 | 12:15 AM
htekken's Avatar
no idea....but i would let Honda continuously work on it til they get it right.
Old Oct 4, 2008 | 05:55 AM
It could be a lot of things from simple mechanical (forgot to reconnect to heater core valve), improper installation, faulty part. They installed it and should fix it.
NemoDat
May 21, 2015 06:05 PM
jojomojo
Aug 19, 2013 06:28 PM
mellospace
Mar 27, 2009 08:06 AM
jtimc7
Sep 2, 2007 08:17 AM
jasonsjwou
Sep 11, 2006 07:33 PM
