hydraulic transmission mount
I have 2002 Honda Accord (automatic) with 188K miles and what to change the transmission mount that is hydraulic to a solid. Is that a good idea or should I go with the hydraulic. Also is that a job for a professional, I can do it myself if its doable with out special tools.
Originally Posted by Pipe wrench
(Post 379267)
Originally Posted by shipo
(Post 379270)
Which engine, I4 or V6?
You mean the vacuum-operated mount in your other thread? I just wrote something there.
Generally, people have done this and regretted it because of excessive vibrations. But maybe that's OK with you. It's sorta tight space back there, but I suppose it can be done. Car on jackstands, stable supported. Jack under the oil pan to hold the weight. |
Originally Posted by JimBlake
(Post 379276)
