hydraulic transmission mount
Old Feb 23, 2018 | 09:00 AM
Pipe wrench's Avatar
Default hydraulic transmission mount
I have 2002 Honda Accord (automatic) with 188K miles and what to change the transmission mount that is hydraulic to a solid. Is that a good idea or should I go with the hydraulic. Also is that a job for a professional, I can do it myself if its doable with out special tools.
Old Feb 23, 2018 | 09:34 AM
shipo's Avatar
Which engine, I4 or V6?
Old Feb 23, 2018 | 09:39 AM
I have the 4cly 2.3L
Old Feb 23, 2018 | 09:52 AM
You mean the vacuum-operated mount in your other thread? I just wrote something there.
Generally, people have done this and regretted it because of excessive vibrations. But maybe that's OK with you.
It's sorta tight space back there, but I suppose it can be done. Car on jackstands, stable supported. Jack under the oil pan to hold the weight.
Old Feb 23, 2018 | 02:00 PM
The Toecutter's Avatar
I'd probably drop the head pipe off too, just to gain some extra room to work with. I only say that as space in that area to work is at a premium. When I replaced my hi pressure power steering line, I had that pipe off, and could actually reach items I could only see prior to removing it.
jasonfridlund
Jun 14, 2009 11:32 PM
baer77
Feb 27, 2009 03:47 PM
Calm_B4_Chaos
Aug 13, 2008 10:50 PM
bakeaj
Feb 27, 2008 11:47 PM
vdabis
Feb 12, 2008 05:32 PM
