Hyper flow exhaust on 91 accord EX
Old May 14, 2011 | 08:58 AM
crshbandit's Avatar
Default Hyper flow exhaust on 91 accord EX
I just purchased a 91 Accord EX and the only mod. that the kid did to the car was to remove the stock air intake and put a high flow intake on the car. I know nothing about these and I was wondering if I should try and put the stock air intake back on? The car runs o.k. but I want to get the best mileage out of the car that I can and of course, the longest life out of the engine! I asked him about it and he said the aftermarket air intake might even give me a little better mileage and better throttle response. There is also a little air filter that pokes up from the valve cover. It's shaped like a upside down cone. Not sure what that is for either! All I know about these aftermarket air intakes is that the air filters for them are really expensive! Thanks for any suggestions.
Old May 14, 2011 | 10:53 AM
OEM air filter will give equal performance and better air filtration for longer engine life, IMO. Google for a million opinions and a few facts. Primary benefit of OEM air intake assy is noise reduction, so unless you like the sound, ditch it.
Old May 15, 2011 | 12:57 AM
cutlass327's Avatar
Honestly, put the OEM back on if you can. They removed the OEM system, and had to put a small breather on the valve cover since it was originally plumbed into the OEM intake system. Most of those "cold air intake" systems are actually more like a "hot air intake", since 9 out of 10 place the open air filter inside the engine compartment where all of the heat is. If you were to look at the OEM setup, they have a duct that pulls air from the inner fender, the front of the radiator, or some other true source of fresh air.
Old May 16, 2011 | 06:18 AM
crshbandit's Avatar
Thats a good point about the intake air source, never thought of that! Now if I can just get the kid I bought it from to give me the rest of the parts for the old intake , I can get started on putting it back together! It's like a puzzle and I haven't been able to find a good diagram of the air intake so I know how it exactly fits back together. Thanks for the help !
Old May 17, 2011 | 02:16 PM
cutlass327's Avatar
Good luck! I think you'll be happier with the stock stuff.
Got your PM, but this is the first i was able to get on here lately..
Half-fast
North East
May 27, 2014 09:31 AM
Melvin Mathew
Jun 18, 2013 12:28 AM
moshlub
Jul 17, 2009 05:29 PM
Mikes Machine
Feb 23, 2008 07:34 PM
Breeze
Oct 10, 2006 06:20 PM
