I have 1998 accord.V6
Old Aug 6, 2011 | 09:58 PM
ranjodh7158's Avatar
Post I have 1998 accord.V6
Hey, i am wondering if anybody had ever go through this problem. I have an accord which wass parked for couple months. Now when i started it now the rpm will not stay under 1000 rpm and they start fluctuating from 700 to 1500 rpm. If anybody has ever encountered and solved this problem please let me know. I would greatly appreciate your help.
Old Aug 7, 2011 | 12:20 AM
piggylover1985's Avatar
If you drive it a little bit would it clear itself out ? Is the check engine light on ?
Old Aug 7, 2011 | 08:23 AM
If it doesn't clear up w/ driving, try cleaning the IACV and PCV. PCV could be stuck open causing too much air.
Old Aug 7, 2011 | 09:01 AM
Also double check the coolant level in the rad....if low be sure to bleed the air out when refilling and have the heat set to max.
kc68
Jun 16, 2016 05:17 PM
Rilex
Aug 14, 2015 12:04 AM
rockhoundrob
Sep 3, 2014 09:07 PM
davidg99
May 5, 2011 11:59 PM
Aug 9, 2006 12:34 PM
