I have problems with ABS!!! Honda Accord EX V6, 2.7L 1996
I need help, When I start the engine, I hear a noise in the system of ABS so got a 30 sec. then disappears ..... What I can do specifically for him to disappear ????, and so every time ... Help please!!!!:(:(:(
That older system is supposed to pump up pressure into an accumulator when you first start the car. That's normal.
Does the ABS warning light come on at the beginning & then go out? That's to check if the bulb is OK. Does the ABS warning light come back on & stay on? If not, then the ABS system should be OK. If the warnign light DOES come back on, read the error code (search this board for instructions). |
Also check the brake fluid level in the ABS res.
