I have problems with ABS!!! Honda Accord EX V6, 2.7L 1996
Old Nov 5, 2010 | 12:38 AM
Andrew657's Avatar
Default I have problems with ABS!!! Honda Accord EX V6, 2.7L 1996
I need help, When I start the engine, I hear a noise in the system of ABS so got a 30 sec. then disappears ..... What I can do specifically for him to disappear ????, and so every time ... Help please!!!!
Old Nov 5, 2010 | 01:42 PM
That older system is supposed to pump up pressure into an accumulator when you first start the car. That's normal.
Does the ABS warning light come on at the beginning & then go out? That's to check if the bulb is OK.
Does the ABS warning light come back on & stay on? If not, then the ABS system should be OK.
If the warnign light DOES come back on, read the error code (search this board for instructions).
Old Nov 5, 2010 | 08:44 PM
Also check the brake fluid level in the ABS res.
93Accord2.2
Nov 7, 2013 07:10 AM
DongTran
Jun 6, 2010 09:41 PM
madsteez
Oct 28, 2008 09:27 PM
MichaelEXL
Mar 3, 2006 06:12 AM
MichaelEXL
Dec 5, 2005 03:46 AM
