I need imediate help please
Old Jun 23, 2008 | 12:59 PM
  #91
HondaPhyco's Avatar
Default RE: I need imediate help please
Im still waiting 4 UPS, today is delivery day, im anxious, i really hope its the ECU if not i will be very pissed. But iwill let you guys know i will not leave you high and dry.
Old Jun 23, 2008 | 01:14 PM
  #92
HondaPhyco's Avatar
Just curious what damage did this gas do to my throttle body and lines? and how to get gas out of cylinders, do i just crank the engine a bit to get it out or us a turkey baster and long tube.
Old Jun 23, 2008 | 03:48 PM
  #93
It probably did very little damage to the throttle body. There is a slight chance that it did damage to your throttle posisiton sensor. Your check engine light will come on if that is the case when you try to start the car.
The gas in the cylinders should have evaporated by now. If you remove a spark plug, you should not get a strong smell of gas.
Old Jun 23, 2008 | 04:03 PM
  #94
I expect no damage at all?
Take out the plugs & let it evaporate.We should have suggested that a long time ago. If there was actually a puddle of fuel on the pistons, it probably washed the oil down into the crankcase. Leave the plugs out, leave the ECU unplugged completely, crank the starter to get some oil back on the rings.
Open the oil fill cap. If it smells like gasoline, then change the oil whenyou get it running.
Old Jun 24, 2008 | 07:36 PM
  #95
HondaPhyco's Avatar
Ok guys big issue,
I ordered my package on the 16th. Suppose to be shipped on the 23rd, reschuduled to 24th, ok fine.
today is the 24 come home, my note is still on my door no package and no intent of delivery notice. Driver said he attempted to deliver at 3:24 lol....@ 3:24 i was in the living room right next to the door. No way i missed it.
Called SC and they are making a complaint, They are going to call me back in the morning and im going to let them know i want my package first thing in the morning. I was so happy to come get my car fixed, and all my hopes came crashing down. [:@]
Old Jun 24, 2008 | 08:43 PM
  #96
That sucks. I'm sure that the shipping company will get it to you tomorrow.
Old Jun 26, 2008 | 12:58 AM
  #97
HondaPhyco's Avatar
OK Guys,
Well I Got the package, Put the New ECU in, Its a big FIX guys....
New One Works great, Well I put everything back together, and Tried to start car, hesitated at 1st but...
eventually after some cranking it started to putter, putter... and Start up, lots of black smoke.....But Car still stutters a little, throttle sound kinda loud, and need oil change from gas in oil. Car runs fine. NO C.E.L yet. What other precautions should i take, i tried to grive as hard as i could on free way to heat things up, and get air flowing, bad idea? Some loss of power.
Old Jun 26, 2008 | 10:09 AM
  #98
Much fuel in the oil?? I would have driven real easy, or just idled awhile. Then change oil.
Once it starts reliably, reset the ECU so it canre-learn the idle control. Then:
Start without touching the gas pedal at all.
Let it idle to warm up without touching the gas pedal at all.
Maybe put some Techron or some kind of injector cleaner into the gas tank incase all the recent stuff has got them dirty?
Old Jun 26, 2008 | 11:59 AM
  #99
HondaPhyco's Avatar
got four new inject from the junk yard, im changin oil. theguysaid no fuel in oil. i did letit idle for thirty minutes. i will reset my ecu later on today. now my egr value still has problems.
Old Jun 26, 2008 | 05:12 PM
  #100
I'm glad that the replacement ECU got the car up and running. To reset the ECU, pull the 7.5 amp radio/backup fuse in the engine bay fuse box for a minute. That will clear the memory.
The oil change may help. You should pull the tube going to the throttle body and make sure that the throttle plate is clean.
A faulty EGR can cause the engine to stumble. Since this thread is extremely long, start a new thread about the EGR problem.
