indicator lights
Old Oct 24, 2009 | 07:33 PM
drummer1279's Avatar
Default indicator lights
ok so Ive tried checking all of the door sensors and such and cannot find anything wrong, however, all of my indicator lights for a door being open all stay on constantly. anything else I could check or is there a way to just unplug them because its not affecting the running of the car. just getting on my nerves when Im driving.
Old Oct 26, 2009 | 08:05 AM
Each door has a switch that's like a rubber-covered push-button, near the bottom of the rear edge of each door jamb. Play with those, maybe one has come loose or something?
I think the trunk switch is built into the latch somehow, but I've never had to dismantle that so ???
Old Oct 26, 2009 | 06:18 PM
ok I'll give that a whirl. yeah its irritating driving and the car telling me I have brake lights out and my trunk and all 4 doors open
Old Oct 27, 2009 | 06:23 AM
Any ONE door switch. I'm pretty sure that warning lamp isn't smart enough to indicate each individual door.
The "Brake Lamp" warning can be set off by a brake-light bulb thats BEGINNING to go flaky, or by a dirty or corroded socket. It's triggered by unbalanced wattage from side to side, and some people have to replace ALL those bulbs just so they match.
Old Oct 27, 2009 | 07:28 PM
you know I have an 1156 bulb in my rear window brake lamp socket. could that cause it?
Old Oct 28, 2009 | 07:24 AM
I don't know what bulb is SUPPOSED to be in there? A bulb of the wrong wattage should set off the warning lamp.
Old Oct 30, 2009 | 01:38 PM
i pulled it up its like a 3225?? something like that. but it was also almost 4 bucks for one bulb. and I had a spare 1156 lying around so I went with free
Old Nov 2, 2009 | 08:21 AM
Got another 1156?? Maybe OK if both sides are the same. I don't really know the difference between 3225 vs. 1156.
Old Nov 8, 2009 | 07:25 PM
its the high mount brake light I have the 1156 in and it still works. disconnected cleaned and reconnected all the sensors on the door jamb and they are still bright on. going to try just unplugging all of them next to see if that works.
Old Nov 9, 2009 | 08:10 AM
Oh yeah, I forgot you said it's the window light...
Google 3225 & 1156 to see whether the wattage is different? I can only guess that the warning is set off by the wattage being incorrect. That's pretty much the only thing that can be measured & compared against what it should be.
Otherwise, I think there's some kind of module in the back of the car that "watches" the brake lamps & compares their wattage. Maybe that module is messed up?
