injector installation
Old Feb 15, 2011 | 02:24 PM
honDUHchick's Avatar
Default injector installation
when i reattach the fuel rail with injectors, my injectors are still loose.....mainly my 1st and 4th injector. the bolts have been tightened all the way and i'm a little unsure why i can still wiggle them.
98 accord 4cyl vtec
Old Feb 15, 2011 | 02:40 PM
g22cd5's Avatar
Supper Moderator
are you sure you have all the rubber O rings and they are not bad?
Old Feb 15, 2011 | 03:25 PM
NEW O-rings on the injectors?
They get hardened with age & heat, so they don't seal any more after you take it apart & put back together.
Old Feb 17, 2011 | 12:59 AM
yea new o rings, but they seem to be able to slide up and down in and out of the fuel rail, almost as if the fuel rail didnt tighten up to the block as far as it should have. i think i have it fixed tho, ive been able to drive my car again since yesterday
Old Mar 5, 2011 | 04:04 PM
ok through all of this, injectors helped ALOT. but however, i have gotten to be able to do a compression check and my 1st cylinders sittin at about 20, dead. and my 2nd is at about 140, too high. so i just thought id keep u up to date on my issue and let yall know thats my problem. im pulling my head off and getting a new one instead of sending it off for headwork. joy. lol
Old Mar 5, 2011 | 07:11 PM
Do a wet compression test do decide whether it's rings vs valves?
Old Mar 5, 2011 | 07:40 PM
well either way when i take the head off i will check my rings too just to be sure.
bobs87
Feb 14, 2006 05:48 PM
FlyLow
Dec 4, 2005 10:45 PM
dinzer
Aug 9, 2005 11:17 AM
jayhova804
Jun 20, 2005 03:49 AM
Mar 1, 2005 09:39 PM
