-   -   intermittent brakelight and turn signal (https://www.hondaaccordforum.com/forum/general-tech-help-7/intermittent-brakelight-turn-signal-6556/)
Georgiaboy98 Dec 19, 2006 08:34 PM
The idiot light came on and I thought it was the bulb so I replaced them I noticed them go on and off when I touched the wires going in to the plastic plug! Now sometimes they work sometimes the don't it sounds like a bad ground to me but I'm not sure where to look? This is the left and right side ! I checked threads and did not see this one. Thanks for any help you may have![:@]
hondadude Dec 19, 2006 08:45 PM
RE: intermittent brakelight and turn signal
Look at the bottom of the socket where the bulb 'nubs' meet the socket connections. I've seen them be flat and make poor contact.
Sometimes it's possible to build up some solder on top of them to fix the problem.
Georgiaboy98 Dec 20, 2006 10:11 PM
Thanks hondadude I did that and the turn signals are working for now but one brakelight is still out! So its still not quite fixed!?
ArcticHonda Dec 22, 2006 12:29 AM
Check for continuity at the bulb sockets...that will tell you if the problem is up-stream from there. Check out this post for more info: https://www.hondaaccordforum.com/m_34058/tm.htm
