intermittent brakelight and turn signal
Old Dec 19, 2006 | 08:34 PM
Georgiaboy98
Default intermittent brakelight and turn signal
The idiot light came on and I thought it was the bulb so I replaced them I noticed them go on and off when I touched the wires going in to the plastic plug! Now sometimes they work sometimes the don't it sounds like a bad ground to me but I'm not sure where to look? This is the left and right side ! I checked threads and did not see this one. Thanks for any help you may have![:@]
Old Dec 19, 2006 | 08:45 PM
hondadude's Avatar
Default RE: intermittent brakelight and turn signal
Look at the bottom of the socket where the bulb 'nubs' meet the socket connections. I've seen them be flat and make poor contact.
Sometimes it's possible to build up some solder on top of them to fix the problem.
Old Dec 20, 2006 | 10:11 PM
Georgiaboy98
Thanks hondadude I did that and the turn signals are working for now but one brakelight is still out! So its still not quite fixed!?
Old Dec 22, 2006 | 12:29 AM
ArcticHonda's Avatar
Check for continuity at the bulb sockets...that will tell you if the problem is up-stream from there. Check out this post for more info: https://www.hondaaccordforum.com/m_34058/tm.htm
BigmoneyG
Jan 28, 2014 12:47 PM
mattcadieux1
May 8, 2013 08:45 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
nva_2007
Aug 20, 2009 12:25 AM
Ntegra
Oct 9, 2006 12:37 AM
