Interpreting Results Of Compression Test
Old Mar 31, 2014 | 08:01 PM
Hondahonda's Avatar
Default Interpreting Results Of Compression Test
Ok, so I finally got around to doing that compression test, now that my cars all good and squared away thanks to you wonderful people of the Honda forums.
I did the test with the engine at operating temperature and I got some weird results. All the dry/wet readings are just about the same. I think what happened was the oil in my spark plug wells probably fell on top of the cylinders when I removed the spark plugs. Dang nab it.
For cylinder #1 to 4, I have "dry": 120 psi, 135psi, 128 psi, and 130. Wet is pretty much inconclusive.
So, since I don't really want to wait and redo it tomorrow, how do my numbers look? Assuming these are the "wet" numbers. As far as I see, they all look about uniform. Can anyone tell me what the service manual says is good PSI for dry & wet compression test?
ryjo
May 9, 2015 06:32 PM
giulio76
Mar 12, 2013 05:48 PM
Corey-Ross Miles
Dec 10, 2012 02:04 PM
importedminds
14
Jun 30, 2008 10:14 AM
