compression test results , thinking of turbo
Old Jun 18, 2008 | 09:33 PM
importedminds's Avatar
Default compression test results , thinking of turbo
ok, so i am looking to turbo my car, 96 accord lx , 2.2 non vtec f22b2 5 speed, odometer shows 197,xxx , but by the way it drives i figure maybe not original engine, so i did a compression test to see how it was running, this is what i got,
180 , 187 , 180 , 190, thats from left to right looking at the engine, i believe 4,3,2,1 ...what do you guys think, also please see my post in general tech help, i believe there may be a small piece of porcelen in the cylinder from a broken plug, could this be a problem???
Old Jun 19, 2008 | 06:26 AM
KevinAccord's Avatar
Default RE: compression test results , thinking of turbo
good compression... about the piece of porcelain... take it out... it is a big issue!
Old Jun 19, 2008 | 08:47 AM
BlkCurrantKord's Avatar
If there was a piece of porcelain in there, you'd know it.
Old Jun 19, 2008 | 01:45 PM
your running the car??? I thought it was "under-construction"... then Blk is right...
Old Jun 19, 2008 | 05:48 PM
oh it definatly under major construction, but still a driver, anyways, i am guessing there is no procelin in there as i drove the car today to and from work, about 45 minutes, and she's running just fine, although i am still getting some oil in the plugs even after a vavle cover gasket change, hmmm, anyways, so this is good compression?? so any other tests i can do before deciding to turbo this engine, as i said it runs really strong, my friend has an 01 civic d17 w/ aem cai, and spoon headers and skunk 2 exhaust and i walk him everytime, but he is not a great driver, anyways , i really feel this is not the original engine, and has alot less miles than odometer is reading, any info on help or tests i can do to fully determine the age and condition of my engine is definatly appreaciated, thanks guys
Old Jun 20, 2008 | 12:39 AM
nafango2's Avatar
you want to turbo it?
knock yourself out. If the engine starts to burn oil like a mother, you can always swap in a JDM and just hook up the turbo to that.
Old Jun 20, 2008 | 02:20 PM
can't you just call the guy/gal you purchased your car from and ask him/her what change he/she made? or call the dealer if that's the case...
also check the engine # and see if it matches your vehicle... (police do that to check for stolen engines)
Old Jun 20, 2008 | 05:21 PM
no, can't find the number of the guy i bought it from, where can i find engine numbers?
Old Jun 24, 2008 | 01:14 PM
let me check on my car and I'll let u know
Old Jun 24, 2008 | 06:04 PM
thanks kevin i appreaciate it
