Jack stand pads?
So whenI was doing all the work on my car I had it on stands that were under the rocker panel jack points behind the front wheels. I wasn't "totally" comfortable with this as there isn't a lot of solid contact with the stands. I saw in the manual they had some kind of rubber pads for this? Anyone know where to get 2 or 4 of these?
BTW I usually put the stands at the front of the car where the front cross member bolts on. It seems to be a very solid point but I couldn't do it there since I needed to lowerthe cross member to do the timing belt. Anyone else use that as a place for stands? Any reason I shouldn't put them there? |
RE: Jack stand pads?
I'm not sure on the rubber pads but I personally usually put the stands on the frame right behind where the A arm comes back to the frame. That way everything is available to be worked on plus it makes for good solid contact.
I use the horizontal sway bar bushing brackets as support points on front. It fits the cupped shape of the jack stand supports nicely. On rear I align as best I can and accept some damage the the vertical frame member.
I've considered making a slotted piece of wood to allow straddling the vertical support member and get support either side on the frame, but haven't done it. good luck |
these lift points are designed to support the weight of the vehicle. they are connected to the strongest part of the vehicle. fyi - supporting the vehicle by the subframe or other part of the frame can bent the subframe or vehicle frame.
http://img28.picoodle.com/img/img28/...dm_d792307.jpg |
ORIGINAL: HondatechAV6 these lift points are designed to support the weight of the vehicle. they are connected to the strongest part of the vehicle. fyi - supporting the vehicle by the subframe or other part of the frame can bent the subframe or vehicle frame. http://img28.picoodle.com/img/img28/...dm_d792307.jpg |
i am not terribly comofortalbe with the contact area between the jack stand and the jack pad, but i've used it without problems
on the truck i just used the frame. |
the subframe doesn't need to be supported, those lift points are designed with the vehicles center of gravity in mind.
ORIGINAL: HondatechAV6 the subframe doesn't need to be supported, those lift points are designed with the vehicles center of gravity in mind. Thanks for the replies guys! |
if you are refering to the pads as seen in the pictures above those look to be the type of pads you'd find on an actuall hydraulic lift and not just a jack...
No that's not what I am talking about. In another pic in the same part of the manual the show pads that sit on top of your jack stands with a groove in them for weight distribution/stability.
