Jolt in reverse when cold
My 02 Honda Accord when cold will jolt when put in reverse. I noticed the front passenger side motor mount is broken. Could that mount cause the problem? Anyone else have this issue?
Engine? Transmission?
A broken mount can certainly cause that. Verify by opening the hood & have someone watch as you shift into reverse. Look for excess movement. I'll assume an automatic transmission. When cold, the idle RPM is raised by the cold-start system. So maybe part of that jolt is simply because of engaging any gear while the RPM is above 1000 or so. So what is the RPM actually during a cold-start? Maybe the Base-idle setting could be checked?? https://www.hondaaccordforum.com/for...e-speed-38734/ (If you have a V-6 then I'm not sure whether the Base idle business is any different) |
Thanks for your reply. That makes sense. I do have a front mount broken. I just bought the car and that is a good logical answer.
You didn't answer what engine?
IF you have a 4-cyl automatic, the rear engine mount is also suspect. It's vacuum-operated, & supposed to get soft during idle in-gear (R or D) & hard all other times. |
It's a 4cyl automatic.
Will this automatic transmission mount cause excessive vibration when instantly in need of a sudden braking? I guess I should be checking these mounts failure
4 Attachment(s)
Not sure if that scenario really pinpoints the failure, but here's how to check the vacuum-operated mount.
Get a helper you trust... That rear mount (down low between trans & firewall) has a vacuum-hose connection. Check the hose for dry, cracking, broken, disconnected, stuff like that. Follow the hose to a solenoid valve nearby. Disconnect the electrical connection to that solenoid. Have your helper in the driver's seat, with the engine running & all warmed up. Shift into DRIVE or REVERSE and hold the brakes. Foot OFF the accelerator pedal. You reach down & disconnect or reconnect that electrical connection. There should be a noticeable difference in vibration with it unplugged vs. connected. If there's no difference, you have to figure out: - Bad engine mount - for example torn & leaking vacuum. - Bad vacuum hoses - leaking vacuum. - Bad solenoid valve - not switching open/closed. - Bad wiring somewhere in the car... |
I'll do that, thank you so much for your time and advice.
