Just a Few Questions
I need to replace the outer right CV joint boot and would appreciate some advice.
1.) Is there any reason why I should not just jack up that side instead of the entire front section? 2.) Is it easier to proceed by dismantling the inner joint...and fit the new boot from that end? 3.) Does the task become very difficult absent a vise to hold the axle? 4.)Any special tips for separating the lower ball joint? Finally...having removed the drive shaft from the transmission, is there any danger of gears falling into the vacant space and impeding reinsertion? Thanks in advance for any insights |
I'm going to bet you find that replacing the whole cv shaft vs the boot and joint is cheaper......you can get a new cv shaft for ~80......just a boot and outer joint,,,,,I've got that ~$200.
So, find the best place for a reman or new cv shaft and replace the whole thing.....which IMO takes 1,2,3 out. For #4, debate. Me, a well placed "hit" by a hammer and she pops right out. |
(Post 290681)
Hello New Member
1 Attachment(s)
Welcome to the information shop..Off you go to your local AutoZone with your credit card in hand and buy yourself a lifetime waranty'd product.
They will also give you directions on how to put it on your car and will even loan you the tools to do the job.. Have Fun... :D WheelBrokerAng :) |
You misunderstand me. There is nothing wrong with the joint, i'm simply replacing a recently torn boot. I have the boot, which cost less than $5, and i'm now seeking the most efficient and safest way to install it. Thanks
You can replace the boot of course, however it is a tedious and messy job. That said there are some good reasons to replace the boot, if this is the OEM cv axle. Over last two years I had tremendous problems w/ quality of Autozone CV axles and would not use them again (check my posts). If you decide to replace consider sourcing a higher quality product from Raxles or other premium cv axle builders.
Download the OEM manual from links in DIY forum Online Manuals post. This has the procedure. It is possible w/o special tools but tedious. Also suggest searching and viewing youtube videos on the subject. I've found ericthecarguy, richpin06a, scottykilmer, and briansmoble1 are good sources, but there are other good videos. I uses a ball joint lifter which is available from many online sources for about $20. It prevents damage to the BJ boot. I'm skeptical about hammer use on knuckle to release the lower BJ, but maybe so. good luck |
Originally Posted by Accord_Ras
(Post 290726)
