just need the straight forward help no bs no time
Old Aug 8, 2013 | 08:19 AM
mikespieceofdung2012civic's Avatar
Default just need the straight forward help no bs no time
Ok sorry I know this isnt an accord but its close .
I have a 2012 civic there is no power repeat no power to the interior lights or any item nothing turns on at all . Battery shows a good charge there are o ly t fuses which show current via light test .all the others dont come on checked both sides of fuse , my horn does go off id be goi g off now if I hadnt removed the fuse .
Old Aug 8, 2013 | 08:54 AM
Dr. Drivability's Avatar
you may have no time, and are obviously frustrated, but we need some BS, like the engine/trans/trim level (ex, dx etc..) what happened right before this problem? any work recently done? stereo, alarm added? what else have you done or checked?
Old Aug 8, 2013 | 09:12 AM
shipo's Avatar
How about taking the car to the dealership and have the issue repaird under warranty?
Old Aug 8, 2013 | 09:14 AM
Im running 1 orion hcca 15 with a 10,000 watt hifonics amp
6 orion hcca 6.2 mids
alpine iva 505
1hifonics 1000.4 amp
3 optima batteries in parralel
1 high output 220 amp alt with internal regulator .
I was hooking up the alpine to the battery direct having turn on issues the key was out of the ignition as we touched the pos and neg just tiny spark . I got in the car this morning to leave and as soon as I turn we d the key the horn was blaring . I checked all the fuses and notived the whole panel inside wasnt getting power , its a civic 2012 lx
Old Aug 8, 2013 | 09:16 AM
Checked under hood h a lf of that panel isnt getting power
Old Aug 8, 2013 | 09:19 AM
They already pulled me aside to discuss my modifications and warrenty
Old Aug 8, 2013 | 09:23 AM
The alarm is factory been having issues with that as of late whenever I disconnect batteries I need to put thekey in the on position then hookup the batts or else when I turn the key the alarm goes off
Old Aug 8, 2013 | 09:25 AM
ah...some light is shed. there is a 100 amp fuse in the front underhood fuse box. have you checked that? with all the electronics you've got going on, doubt the dealer is going to fix anything under warranty. anything we come up with here will be a guess at best.
Old Aug 8, 2013 | 09:30 AM
shipo's Avatar
Sorry to say, but you're probably on your own on this one.
Have you tried disconnecting your mods one-by-one to determine which one is causing the issue?
Old Aug 8, 2013 | 09:34 AM
Have not check 100 amp let me do now
