-   -   Just speed sensor problem? Or worse? (https://www.hondaaccordforum.com/forum/general-tech-help-7/just-speed-sensor-problem-worse-3940/)
Will5 Jul 9, 2006 05:17 AM
Hello, I might be buying a 1990 Accord from someone I know.. They are getting rid of it pretty cheap but let me know ahead of time that the speedometer started acting up a while ago. It works sometimes, but others it just stays at 0 and when it does stay at 0 the transmission S light flashes. They thought it was just a speedsensor problem but aren’t really sure.
Does that sound like just a speed sensor or could it be something more? If just a speed sensor is that an expensive fix?
Thanks!
mbo1985 Jul 9, 2006 11:20 AM
RE: Just speed sensor problem? Or worse?
Sounds like the speed sensor to me. Mine burnt out in my honda, so it seems to be a pretty common thing to go out.
WheelBrokerAng Jul 9, 2006 01:04 PM
Hi Member..
Has anyone thought of just checking the speed-o-meter cable to see if its cracked or even broken?
Check it out!
WheelBrokerAng :eek:
mbisenius Sep 12, 2006 12:37 AM
Mine does the same thing. I start it and start driving. The speedometer is at 0 and won't move. Then in about 2 or 3 minutes the green S starts flashing. Then about 2 minutes after that the check engine light comes on. I put a fire extinguisher in it just in case :-) I've replaced the TCU about a year ago. Any idears?
Slusher Sep 12, 2006 04:01 AM
I would recomend, first, do what WheelBrokerAng suggested, simple first. It does sound as though the VSS is out and it seems to be pretty common after a certain amount of time. VSS replacement is not too hard it is just in a hard to reach area, but nothing that should discourage you. I'm not sure of the procedure on you model or if its universal on most models but I would wait and hear from someone with your same year accord advise you on what goes into it.
deserthonda Sep 12, 2006 05:00 AM
http://techauto.te.funpic.org/vss.php
hope this helps
Accordn2dis Sep 13, 2006 07:22 PM
problem
same problem here
