Key remotes not working...
Old Sep 23, 2011 | 10:59 PM
cadria04's Avatar
Default Key remotes not working...
Recently had to replace master control switch on driver's door that operates widows/locks. Had switch replaced at private garage. Switch working correctly. However, right after switch replaced, both keyless remotes quit working. Both working, correctly, prior to switch replacement. Any assistance is appreciated/welcome.
Car is 2006 Honda Accord, 4 cyl, w/ Auto.
Old Sep 24, 2011 | 12:12 AM
You need to reprogram the remotes. In the following link, follow instructions on page 9.
tegger.com/hondafaq/misc/98-011.pdf
Old Sep 24, 2011 | 12:16 AM
Here is the information on programming the keyless entry remotes. Have all of them with you when you do this. The instructions seem long, but they aren't too bad.
The codes of up to three transmitters can be stored into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the tailgate are closed.
1.Turn the ignition switch ON (II).
2.Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver by the power window master switch.
3.Within 1 to 4 sec, turn the ignition switch OFF.
4.Within 1 to 4 sec, turn the ignition switch ON (II).
5.Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver by the power window master switch.
6.Within 1 to 4 sec, turn the ignition switch OFF.
7.Within 1 to 4 sec, turn the ignition switch ON (II).
8.Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver by the power window master switch.
9.Within 1 to 4 sec, turn the ignition switch OFF.
10.Within 4 sec, turn the ignition switch ON (II).
11.Within 1 to 4 sec, press the transmitter lock or unlock button with the transmitter aimed at the keyless receiver by the power window master switch.
12.Confirm you can hear the sound of the door lock actuators. within 1 to 4 sec, push the transmitter lock or unlock button again.
13.Within 10 sec, aim the transmitters (up to two additional ones) whose codes you want to store at the keyless receiver, and press the transmitter lock or unlock buttons.
Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14.Turn the ignition switch OFF, and pull out the key.
15.Confirm proper operation with the transmitters.
Old Sep 24, 2011 | 05:02 PM
cadria04's Avatar
Default Thank you
Thank you to the members that responded to my question about my keyless remotes not working after replacing my master window switch on my Accord. Tried the information and after a few tries, the remotes are working correctly. Not sure why it took more than one attempt, but I am not the most technically savvy individual around.
Anyway, thanks again to those that helped.
Not sure where to post this thread, so apologies to the moderators if this is incorrectly placed.
Old Sep 24, 2011 | 08:27 PM
General Tech is the correct place for this (not sure if another mod already moved it)
csh217
Jun 17, 2014 05:53 PM
RAZORMAN
Jun 4, 2012 05:32 PM
cypres
Dec 2, 2008 06:31 AM
BlackPeppy07
Mar 2, 2008 05:39 PM
93Miata
Nov 10, 2005 08:06 AM
