Key will not turn in the ignition at times
Old Apr 30, 2013 | 05:35 PM
Bellbuoy's Avatar
Default Key will not turn in the ignition at times
I just bought a 1997 Honda Accord SE w/ 118,000 miles and have a baffling issue. One of the two keys sometimes will not turn in the ignition. It's not like the key is bound up and turn the steering wheel slightly frees the key, sometimes I can turn the wheel end to end and the key still will not turn. Anyone else experience this? Causes?
Old Apr 30, 2013 | 06:09 PM
Keys wear and may not depress the pins to actuate the lock assy. May need to get a new key cut by Honda based on VIN to get a "fresh pattern".
Old May 5, 2013 | 09:59 AM
mallonpaulj's Avatar
Default A little lubrication may help - WD 40
Sticking keys can be helped by using either graphite spray or WD-40 in the key hole. I was about to change my trunk lock cylinder on an older Malibu when a key/lock shop pulled out the WD. Three shots and the lock 'puked' out a lot of dirt and grime. I just bought the rest of the can from him ($4) vs a new lock cylinder ($30). One piece of advice on an ignition key, put some rags on the floor mat to catch any stray drips from the steering column. Couple sprays and just work the key as normal. Should help.
93 Accord SE Coupe
csh217
Jun 17, 2014 05:53 PM
KerryBurnham
Aug 19, 2013 03:38 PM
cchandler
Jan 23, 2013 11:27 PM
bjr001
Jun 27, 2009 03:47 PM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
