Knocking in Steering while turning
Old Sep 17, 2008 | 01:36 AM
joecool71_3
Default Knocking in Steering while turning
So recently while driving my car while I am turning I get a continuous knocking in the wheel and it seems some in the front suspension. It also knocks a little bit while going through dips, bumps, etc.... Now I was thinking maybe CV joint, but wanted to see what a couple of you guys think it might be. Any input would be greatly appreciated.
Thanks,
T
Old Sep 17, 2008 | 02:11 AM
Default RE: Knocking in Steering while turning
The CV joint made a clicking sound when I turned. Look for grease everywhere near the outer CV joint boot. The boot is likely torn.
You should inspect other worn suspension components while you are down there. The upper and lower ball joint for excessive play. The sway bar endlinks for deteroriatoin.
Old Sep 17, 2008 | 08:13 AM
falkore24's Avatar
x2 .... CV sounds right
Old Sep 17, 2008 | 05:08 PM
deserthonda's Avatar
it sounds like a loose spare tire......seriousely input year and model , it will give us a better idea
noise on turns . like it has been said, sounds like a worn outer cv joint.. but the noise over bumps is a different matter, could be struts, worn or lose suspension parts ..
huhdo
Aug 30, 2012 09:06 PM
andrew404
May 16, 2010 08:41 PM
shelbydog25
Apr 16, 2009 12:04 PM
mbnjagn
Mar 13, 2008 03:20 AM
FlyLow
May 8, 2006 06:00 AM
