Leak in Radiator Area
Old Aug 26, 2019 | 10:56 AM
cprinci's Avatar
Default Leak in Radiator Area
Appears to be a leak where from the radiator, coolant is bubbling out underneath hose that runs to overflow, with noticeable amounts of coolant on fan housing. Trying to determine exactly what to replace, is it a seal, the entire radiator, or something else?
Old Aug 26, 2019 | 12:55 PM
shipo's Avatar
Assuming your arrows are pointing to the top tank, then yeah, looks like a whole new radiator.
Old Aug 26, 2019 | 07:46 PM
If the crimp between the plastic and the aluminum is leaking or a crack in the plastic, then you'll need a new radiator. I've used Denso radiators on my Hondas and they haven't caused me problems.
Old Aug 26, 2019 | 08:50 PM
shipo's Avatar
I second Denso radiators.
Old Aug 27, 2019 | 08:44 AM
cprinci's Avatar
Thanks! After looking back definitely was the radiator. Got a new one swapped out, and back on the road.
Old Aug 27, 2019 | 11:53 AM
rockhoundrob's Avatar
Careful there... I replaced a radiator due to a leak near the radiator cap and leaking onto the cooling fans and the SAME thing happened to the NEW radiator.
It turned out that the little overflow hose was leaking every time the radiator cap let off pressure. See where that drop of water is?
That's where the coolant was shooting out from the connection from that little hose connection in my situation.
After I saw what was happening I got a little hose clamp and clamped it on the little hose. After that, problem gone.
Just make sure it is not that little overflow hose that is leaking, before you replace the radiator.
Old Aug 27, 2019 | 02:40 PM
cprinci's Avatar
Thanks for the heads up I'll keep an eye out, but I did notice some bubbling coming out of the crimp between the plastic/aluminum noted above, fairly confident that was the culprit.
19962door
Jan 27, 2017 07:46 AM
whiskywaterwine
May 31, 2016 03:03 PM
skyfire322
Dec 12, 2013 06:53 AM
lashlecf
May 12, 2008 11:16 AM
Oct 5, 2005 08:49 PM
