Leaking Antifreeze
Old Mar 17, 2010 | 04:16 PM
joeysworld's Avatar
Default Leaking Antifreeze
1994 Accord LX
While changing the oil today, there was a steady drip of antifreeze right next to the oil plug drain.
We bought the Accord used at about 196k miles, and I believe the previous owner had replaced the timing belt a few thousand miles before he sold it to us.
The area to work in is very compact. I have considered using some BarsLeak opposed to changing the waterpump/waterpump gasket. I undersdtand that the antifreeze does no good to the timing belt.
Is there any pictures/videos here on how to replace a water pump?
Old Mar 17, 2010 | 04:46 PM
Look for a thread in DIY about changing the timing belt. It's the same job, because the waterpump is driven by the timing belt. Once the timing belt is off, the waterpump is right there.
Old Mar 17, 2010 | 04:50 PM
joeysworld's Avatar
I'll do that.
Thanks
Old Mar 17, 2010 | 06:23 PM
deserthonda's Avatar
woooooo........ pressure test the system and properly identify the leak.. could be a hose.. do not replace any parts till you are 100% sure where the leak is coming from......
Old Mar 17, 2010 | 06:34 PM
uummmmm.... YES!
Timing belt & water pump is an awful big job if it turns out the leak is somewhere else.
Old Mar 17, 2010 | 11:13 PM
96FiveSpeed's Avatar
I would not use any leak sealers since they can clog the heater core.You are better off finding the leak than pouring a band aid fix into there.
Old Mar 18, 2010 | 02:04 AM
kris_loehr's Avatar
The waterpump is not in the area of the oil drain plug.
Old Mar 18, 2010 | 06:56 AM
Leaking waterpump drains through a weep-hole towards the back of the enigne, but still it's at the pulley-end of the engine. It could travel over towards the drain plug, but it SHOULD(?) be apparent where it's really coming from.
There's a block-drain-plug near the oil filter. If that's leaking, it'll drain down near the oil-drain-plug.
There's a steel tube running across the back side of the eninge, from the thermostat to the waterpump. Couple little hoses clamped on it, so one of those might be leaking.
TEST IT. Clean everything up as best you can, then get/rent/borrow a pressure tester. It attaches where the radiator cap goes, and you can pressurize the cooling system cold. That way you can look for the leak & find out where it's REALLY coming from.
Old Mar 18, 2010 | 04:59 PM
kris_loehr's Avatar
I had a little trouble finding the right adapter for the radiator on my 1995 with my pressure checker. I think I got it off Amazon but others sell it. Finding where a leak starts from is hard without it. I have a feeling it is going to be something easy to correct.
Old Mar 15, 2011 | 11:31 AM
DADEZACCORD's Avatar
did you resolve this problem?im having the same problem now after i put in a thermostat. my accord didnt have one in it. since they say in florida you dont need one. i think i will take it out and see if the leaking starts again.reason for changing/putting in thermostat was because the temp on the car was passed half close to line where the red is but then it would fall back down after fans came on. so i thought maybe bad thermostat is the problem.but now im reading about weephole drains and also possibly bad water pump now.also i have a 97 accord lx, automatic with 131,000k on it.
