LED cluster conversion now the fuel gauge not working
Old Jun 11, 2011 | 08:46 PM
piggylover1985's Avatar
Default LED cluster conversion now the fuel gauge not working
Hi guys, i'm doing an LED conversion for my instrument cluster, i'm kind of tired with the look of the cluster on my 99 Accord, so i pulled the cluster out and took everything apart, after i soldered all the LED lights and put the cluster together. I marked the fuel gauge level before i disassemble it, so it put it back where i had it mark but now the needle says it's empty but it should be like half way. Is there an easy way to reset the gas needle for the gauge ? Here's some pic of the unfinished cluster. ImageShack Album - 4 images
Old Jun 12, 2011 | 08:07 AM
So did you have to remove the needle, is it secure to the "pin"....is the ground from the level sensor connected.....sorry, I bet you've already checked these but that is all I can really offer....
Old Jun 12, 2011 | 08:20 AM
Yes i had to remove the needle, bad idea but i tried prying on it with care by using a fork and a spoon. I'll pull the cluster out again and recheck the needle.
Old Jun 12, 2011 | 09:22 AM
A dab of non-hardening silicone???? just an idea...good luck.
Old Jun 12, 2011 | 02:36 PM
This is a costly test nowadays, but fill up the gas tank to see if the needle moves up. You want to see if the gauge is actually working.
Why did you need to remove the needle?
Old Jun 12, 2011 | 03:17 PM
I had to remove the needle to to the LED conversion, because the new light bulbs are in the back of the gauge's face. ImageShack Album - 2 images
Old Jun 12, 2011 | 05:57 PM
I never owned a 6th gen accord. On my 95, I didn't have to remove the needle to take out the speedometer.
Maybe you didn't get the gauge to seat properly in the main circuit board? I'm just guessing here. I am not sure what happened.
Old Jun 12, 2011 | 06:10 PM
Yeah, it's kind of sticky, i'll just have to keep working with it.
Old Jun 13, 2011 | 07:54 PM
Ok i think i'm all set with the fuel gauge now.
Old Jun 13, 2011 | 07:58 PM
Tell us how you fixed it.
