led headlight strip lights
would like these to turn on and off with the ignition. Is there a relay in the fuse box I could run a wire from to accomplish this.
What are you working on?
Are these factory or aftermarket lights, if aftermarket how are they current;y wired? |
2004 Honda Accord V6. After market 19.5 in. strip lights. Arent currently wired. I would like for them to be automatically always on whenever the engine is running. Need an under-hood power source to tap into to accomplish that. I'm not too bright when it comes to electricals.
2 Attachment(s)
This should accomplish what you are describing if you are using a 12 volt LED strip.
Get a Littelfuse Add-A-Circuit MINI and use one of the unused slots in the interior fuse box. No. 29 or 31 slots are unused in the interior fuse box. http://www.littelfuse.com/~/media/Fi...FHM02FHA02.pdf The LED strip should turn on when the ignition is ON and the switch is ON. (If you don't want a switch; just don't add it.) https://www.hondaaccordforum.com/for...ine=1440950691 |
Trust me I hate electrical :shrug:
Just so I'm clear, when the key is in the "on"/pos II or only when the engine is running? EDIT: Slow typing. I see RB posted as I was sleeping on the keyboard :) |
