led headlight strip lights
Old Aug 29, 2015 | 02:07 PM
jandeolsen's Avatar
Question led headlight strip lights
would like these to turn on and off with the ignition. Is there a relay in the fuse box I could run a wire from to accomplish this.
Old Aug 30, 2015 | 06:42 AM
What are you working on?
Are these factory or aftermarket lights, if aftermarket how are they current;y wired?
Old Aug 30, 2015 | 10:51 AM
jandeolsen's Avatar
Default led headlight strip lights
2004 Honda Accord V6. After market 19.5 in. strip lights. Arent currently wired. I would like for them to be automatically always on whenever the engine is running. Need an under-hood power source to tap into to accomplish that. I'm not too bright when it comes to electricals.
Old Aug 30, 2015 | 11:04 AM
This should accomplish what you are describing if you are using a 12 volt LED strip.
Get a Littelfuse Add-A-Circuit MINI and use one of the unused slots in the interior fuse box. No. 29 or 31 slots are unused in the interior fuse box.
http://www.littelfuse.com/~/media/Fi...FHM02FHA02.pdf
The LED strip should turn on when the ignition is ON and the switch is ON. (If you don't want a switch; just don't add it.)
Attached Thumbnails led headlight strip lights-9248d1357077663-installing-led-strip-lights-under-dash-basic-hook-up.jpg
Old Aug 30, 2015 | 11:08 AM
Trust me I hate electrical
Just so I'm clear, when the key is in the "on"/pos II or only when the engine is running?
EDIT: Slow typing. I see RB posted as I was sleeping on the keyboard
spitfire1114
Jan 1, 2013 04:02 PM
Albert W
Dec 10, 2012 04:34 PM
eazycash
Jun 12, 2011 10:41 AM
eazycash
May 10, 2011 09:25 AM
onlinelinkz
Apr 26, 2011 11:30 PM
