Left turn signal - [Confirmed Fix]
Trying to figure out where to post questions:confused: 2003 Honda Accord EX, left turn signal dash indicator and front/rear signal lights stopped working today. Got new bulbs, but still not working. Is there a relay or fuse for just one side or the other? derf41144
LOL, duplicate threads. Redbull deleted one, I deleted the other. So here's this one back again! Sorry about that.
It may be a problem with the turn signal/hazard relay. Inside that relay is actually a circuit board and two separate relays.
https://www.hondaaccordforum.com/for...zard-relay-jpg |
is this located under the hood or under the dash?
Under the dash. It can be a little difficult to pull out.
I think i just saw an older post on this problem. Should be a challenge since I recently had knees replaced. Look out!?!?!?!?!
FIXED - Left trun signal
:D Well as advised it was the trun signal/hazard relay ... and boy was it a challenge to get the old one out. However For anyone whom has the same problem when you go to buy one: Much cheaper on the internet than at local dealer if you can wait. Which I could not: cost $32.00 Plus there are 2 models to the relay depending on your Accord Vin number: Starting with 1 item is 38300-SDB-A03, if Vin starts with a J, then 38300-SDA-A02
Thanks for reporting back that the problem was fixed.
left turn signal.
Same problem- same solution, thanks to this thread.
2003 Accord EXL. |
