Limp mode
Old Mar 29, 2025 | 02:19 PM
Ihatemyhonda's Avatar
Default Limp mode
I have a 04 Accord EX and a couple of days ago I replaced the top transmission mount and positive battery terminal and the next day my car went into limp mode. The day before I did said work, car drove great.
Scanned and found 3 codes two being o2 sensors because I need to replace a broken wire. And p0717 input shaft speed sensor, replaced old sensor with new replacement part, and car is still going into limp mode.
Also changed battery terminal on both pos and neg to better conducting terminals and checked transmission fluid levels "within limits"
Note: car has always had codes for o2 sensors since I bought it from a friend.
This is my daily and really need to figure this out ASAP!!!
Any help would be great!!!!
Thanks!
Old Mar 31, 2025 | 09:30 PM
Moved your post to the right forum for you to get some answers.
When you replaced the transmission mount, were you working near the sensor or near the harness of that sensor?
Old Apr 1, 2025 | 02:14 AM
Not that I am aware of,
I did test the signal wire for continuity from the plug to where all the harnesses connect to the main harness that goes into the firewall. I did get continuity, but while I was doing the test I could hear something like a electric valve being activated.
After replacing the input speed sensor I now have an extra couple of engine codes now. Along with the same code for the input speed sensor code of P0717.
Newest code is P2649.
Old Apr 1, 2025 | 01:22 PM
It might be helpful to post all the codes you are getting to see if they are related. The two you posted don't seem related.
You might want to stop by a parts store and have them test the battery and alternator to see if abnormal voltage is messing up the system.
Old Apr 3, 2025 | 09:26 AM
kris_loehr's Avatar
Did you disconnect a negative battery cable when you replaced the mount?
Old Apr 3, 2025 | 10:19 AM
Yes, I replaced my battery terminals as well.
Old Apr 5, 2025 | 05:09 PM
These codes was already set whenever I got the car.
P0155
P0135
P0154
P0141
Newest codes: after replacing top transmission mount
P0717
P2649
Old Apr 6, 2025 | 02:08 PM
Based on your codes, is this a V6 engine?
The P0155, P0135, P0154, and P0141 are all for the heater circuits in 3 of the 4 O2 sensors.
P0717 is for the input/mainshaft speed sensor/circuit on the transmission.
P2649 is for the vtec solenoid high voltage.
The original four likely have nothing to do with the existing codes, but should be fixed. You mentioned a bad wire. Try to find the location of the damage, because it is possible other wires are damaged and causing the two new codes.
The codes don't necessarily mean to replace a sensor as something upstream like the wiring could be damaged. Since you have a scanner, look at the values and/or voltage the PCM is reporting from the sensors. This can help give you some direction. Testing for power and ground to the vtec and mainshaft sensor may help narrow down the issue.
Old Apr 6, 2025 | 03:55 PM
I do not have a scanner, closest scan tool is over 30 minutes away. And not been able to buy one. And yes it's the V6 3.0L coupe
RAL91
Jan 15, 2023 10:15 PM
EK99HATCHBACK
Mar 5, 2015 10:46 AM
steven78418
Jun 14, 2011 02:56 PM
