Long Cranking
Old Jun 7, 2007 | 08:19 PM
MALSR's Avatar
Default Long Cranking
Sometimes my startup will crank for maybe 10-15 seconds longer than normal. It only happens occasionally and it seems to be when the fuel tank is low (maybe a coincedence?). Also, I resoldered my main relay and the problem has happened before and after that. Other recent work i've done: new plugs/wires, distr. cap and rotor, replaced lower rocker arm seals, fuel filter.
Old Jun 7, 2007 | 10:29 PM
Default RE: Long Cranking
It could be a keyswitch problem. The keyswitch faultcan appear very similar to failed main fuel relay. Only way to know is to look for instrument panel lights when you are having a hard start. If no panel lights, the problem is likely the keyswitch. If lights are on, the fuel filter and fuel pressure regulator are potential problems.
Old Jun 8, 2007 | 06:26 PM
MALSR's Avatar
Could it also be a problem with the coil or igniter?
Old Jun 8, 2007 | 06:39 PM
Coil and ignitor don't tend to be intermittent, but it's certainly possible. Since problem doesn't really exhibit for any length of time, it is very difficult to determine whether fuel or ignition is the problem. You might perform some general maintenance, if the plugs, wires, rotor, and distributor cap have not been replaced recently, or simply wait till problem becomes continuous to diagnose.
An easy one is to look for instrument panel lights when hard start is occurring. If panel lights are off, the keyswitch assy is very likely.
Old Jun 11, 2007 | 08:10 AM
ORIGINAL: TexasHonda
... Only way to know is to look for instrument panel lights when you are having a hard start.
Another way to tell is wiggling the key in different ways when starting. If you can make the problem happen simply by holding the key in a different way, then it's probably the switch.
For example, if it's not starting, try again but don't twist the key all the way to start. Just twist it barely enough to get the starter to run. Or maybe push on the key up down or sideways to see if that changes things.
opaque
Apr 22, 2013 12:17 AM
libra2458
Sep 12, 2011 06:38 PM
tinkerevil
Apr 23, 2011 02:52 AM
5.0stang
Jul 23, 2009 07:24 PM
87kenny06
Sep 9, 2007 11:42 AM
