Loud lifter noise - Do quick fixes really work?
What's up everyone? So my girls 01' Accord (f23a4, I think), has developed a pretty loud noise coming from the valve cover. I think it's a lifter but I'm not 100% sure. Since this noise has gotten louder and louder, her gas mileage has also dropped. I heard that dirty or clogged lifters can affect your mileage, but I don't know how true it is. I heard from that same source that there is a way to put auto. trans. fluid in with your oil for a curtain period and it will clean your lifters and make the noise go away. I know Honda motors have a lot of normal ticks to them, but this isn't normal. Her motor is noisy as hell. Any help would be greatly appreciated. Thanks in advance.
RE: Loud lifter noise - Do quick fixes really work?
Honda 4 cyl engine does not have hydraulic lifters.
I'd say that maybe a valve adjustment is needed. The rockers are usually a little noisy at start up/cold, then quiet down some as the engine warms and the rocker arm expands a little bit. |
ORIGINAL: hondadude Honda 4 cyl engine does not have hydraulic lifters. I'd say that maybe a valve adjustment is needed. The rockers are usually a little noisy at start up/cold, then quiet down some as the engine warms and the rocker arm expands a little bit. |
So a valve adjustment is in order I guess. I've never done one but I've got a book and some good mechanic buddies. Thanks for the help you guys.
There is a few write-ups on it in our DIY section as well
