loud noise when accelerating
Old Oct 28, 2008 | 08:52 PM
cjdm98's Avatar
Default RE: loud noise when accelerating
Have you had someone in the driver seat press the gas and you listen to the engine? To pin point where the noise is coming from, once you know where,then you go from there.
Old Oct 28, 2008 | 09:16 PM
falkore24's Avatar
Maybe a dirty throttle plate?
Old Oct 28, 2008 | 09:31 PM
madsteez's Avatar
It has to be vacum lines,or anything to do with the induction of air. No other part,bearing,belt would make the type of noise you are describing at and only at a particular rpm.
Old Oct 28, 2008 | 09:33 PM
patrickz's Avatar
so it did it befor?
does it affect ur performance? and is it messing up ur engine in any way??
Old Oct 28, 2008 | 10:06 PM
falkore24's Avatar
Madsteez: I wouldn't rule out anything from a description. Who's to say that it isn't a wheel bearing and he's not hearing it from the right place? I think that you are most likely right, but it does not HAVE to be a leak.
Old Oct 29, 2008 | 12:06 AM
Hobbin's Avatar
Hm thanks guys, I'll keep looking and try to diagnose
Old Oct 29, 2008 | 01:02 AM
  #17
deserthonda's Avatar
chk the pcv valve
Old Oct 29, 2008 | 06:59 AM
  #18
If you can make it happen by pushing the engine, keep doing that whilelistening forthe location of the noise. Pinpointing the location of the sound is 90% of the job.
Old Oct 29, 2008 | 09:55 AM
  #19
stevenb17
yeah it was happening BEFORE i put in the SRI. it hasn't affected my performance at all. and as far as i know it hasn't messed up the engine. it's just a loud annoying noise. haha
Old Oct 29, 2008 | 10:00 AM
  #20
stevenb17
it's really hard to pinpiont the noise becuase it only happens when i'm on the road. i've tried to just rev the engine and listen for it but it doesn't happen then. only at a certain rpm while im driving.
