Lower Control Arm Replacement
Old May 15, 2013 | 08:58 PM
RobinsonRicer's Avatar
Question Lower Control Arm Replacement
So if you saw in my other post this is my best option. Im getting the new part and noticed a few things that confused me about the replacement. In the haynes manual it says that you remove the front lower control arm in 3 locations. Im starting to see why that manual sucks. The FSM shows a bit more but doesnt explain it. I see two more bolts on top.
Can I replace this without any special tools to compress the spring or anything that may come lose and not go back together so easily or is this pretty straight forward?
thanks
Attached Thumbnails Lower Control Arm Replacement-previewofldquohondaaccordcoupe1994-1997servicemanualpdfrdquo_zps9cd102cb.jpg
Old May 16, 2013 | 02:51 AM
TerryB's Avatar
The 2 on top are the front sway bar bolts. Pblast them before starting.
Old May 16, 2013 | 08:02 AM
Ok. Thanks
cyberhiker
Nov 1, 2016 10:32 AM
JohnNH
Jan 1, 2015 03:32 PM
Colondo
Jan 25, 2013 09:58 AM
Steve93
Oct 19, 2007 05:02 AM
RoKnAzn
May 21, 2007 06:29 PM
