LUG Stud Replacement 1991 DX
Old Jun 13, 2007 | 04:23 PM
kwallen
Default LUG Stud Replacement 1991 DX
Hello,
The other day I was replacing the brake pads and one of the lug studs broke off. It got very tight and just broke right off. Now on many cars, you could simply pound it out the back and replace. However, on the Accord the rotor is there and is not as easy to remove as some. Can someone please tell me the cheapest way that the stud can be replaced?
I understand that taking the rotors off will be necessary but someone told me that the whole wheel bearing/hub assembly would need to be replaced. Can this be true for just a lug stud?
Thank you for any help.
Kevin
Old Jun 13, 2007 | 05:01 PM
sir_nasty's Avatar
Default RE: LUG Stud Replacement 1991 DX
I'm not certain on the 91 but a number of accords have a small hole of sorts behind the rotors (usually at the bottom) so you can rotate the rotor assembly and line the lug up with that hole in the back then just pound it out and replace it.... If not and you do have to pull the whole assembly yes it can be difficult....
Old Jun 14, 2007 | 06:40 PM
deserthonda's Avatar
what i have done is to, hammer out the old stud, it will come out..
On the new stud, take it to a grinding wheel and gring off part of the round base head . almost 1/2, line the stud up with the grounded part toward the hub,, insert the stud in, either hammer it in ,or get a wheel nut, screw it into the stud , tighten the nut, this will suck in the stud ..
no need to remove anything
adonus348
Nov 30, 2011 11:49 AM
mrmiller99
Sep 22, 2011 07:21 PM
upintheclouds90
Jun 25, 2011 02:17 PM
Hondancali
Jul 17, 2010 09:44 PM
Mike 68
Dec 19, 2008 10:33 AM
