Main Relay or Distributor
Old Aug 19, 2010 | 07:55 AM
Mr.Project8's Avatar
Exclamation Main Relay or Distributor
Year and trim accord :2000 Accord Coupe Lx 4cyl 2.3L
Your request for a DIY write up :Main Relay or Distributor
Any additional notes that need to be added :Car is shutting off when it gets to running temp. When it cools down it runs again till running temp. I believe that its one of the two.
Old Aug 19, 2010 | 08:56 AM
If it happens all the time, put a timing light on a spark plug wire & run it until it warms up & quits. Watch whether the timing light still flashes when it WON'T run.
Main relay switches fuel, it's not in the ignition/spark circuit at all.
I'm moving this to Gen.Tech since it's not a long "procedure" write-up.
Old Aug 19, 2010 | 10:05 AM
g22cd5's Avatar
Supper Moderator
Also by Jim moving this you will get better answers.
Just b/c you filled out a request forum doesn’t mean it has to stay in the D.I.Y area of the forum...thought I just throw that out there.
Old Aug 19, 2010 | 12:55 PM
Okieaccord's Avatar
Mr.Project8
I recently had a trouble shooting nightmare on a 1999 Accord and used the link inserted below to aid in my efforts. Deserthonda suggested the same web site and I think you will find it usefull in your efforts.
http://www.techautorepairs.com/
Old Aug 19, 2010 | 06:00 PM
Ok...Well the reason why i thought it was the main relay was because sometimes when im trying to crank it up it seems like its not getting any gass then i have to wait a couple hours and try again. Now once i get it to start thats when i have the problem of it shutting off. But i only had it not start on me twice in the past month. But the car turning off has been happening for about 2 months. At first i thought it was the Alternator but the works fine. Had it tested and the battery was bad but i havent had the altinator fixed but ive never had an alternator go in and out on me or work after the car cools down. So thats why i came to the forum cause i didnt know exactly what to do. The dealer suggested the Main Relay. Another Mechanic suggested the Distributor. Both mechanics mentioned the same symtoms.:c onfused:
Old Aug 19, 2010 | 06:03 PM
HAHAHAHA Its cool its you guys turf. Im just happy i can get help form ppl with the same cars and awsome knowledge....
Old Aug 19, 2010 | 06:15 PM
g22cd5's Avatar
Supper Moderator
Wish every HAF member would think like you
Old Aug 19, 2010 | 06:48 PM
Lightbulb
Originally Posted by Okieaccord
Mr.Project8
Preciate the info man this site is awesome......still wanna see if someone on here can answer
Old Aug 19, 2010 | 07:02 PM
Does the check engine light turn on when you car stalls? Does your car stall every time it gets to operating temperature?
I would stop by a parts store and have them scan for code(s). Post the code on here. It will start with the letter P and have 4 numbers, like P1234. Most parts stores do this service free of charge.
Also have the battery/alternator/starter tested again. You explanation above is vague about the alternator. Did the alternator test bad/good? If the battery tested bad, then you should replace it. If the battery wasn't charged enough due to a bad alternator, then they can't tell you about the condition of the battery.
Old Aug 19, 2010 | 08:11 PM
Bad main relay, or bad alternator can have very similar symptoms. That's why you should test for spark (timing light).
I've seen SOME places that have equipment to test a battery even if it's not charged. Basically, it charges it & then tests it.
It's a bit unusual, but alternators can be flaky, failing & then coming back to life. Maybe keep doing that for months before giving up & NOT coming back to life.
