Maint Reqd Indicator
Old Jun 21, 2007 | 04:30 PM
Funnyfarm
Default Maint Reqd Indicator
Trying to reset the Maint Reqd indicator light, after serviced It flashes once then continues to stay lit.... Any suggestions? Thanks
2004 31,500 miles.
Old Jun 21, 2007 | 04:31 PM
sir_nasty's Avatar
Default RE: Maint Reqd Indicator
with the car off put the key in the ignition, push and hold your trip reset/odometer reset button, turn the key to the on position and continue to hold the trip/odo reset button for about 15 seconds, the light should flash a few times and then go off. Then you're done!
Old Jun 21, 2007 | 04:35 PM
Funnyfarm
We have tried this but it continues to stay on
Old Jun 21, 2007 | 04:37 PM
sir_nasty's Avatar
Is it the maint required light or the check engine light that is on? If that doesn't work you may be able to disconnect and reconnect the battery cable to reset it, be sure you have your stereo code if you do that though. If it still stays on I'd call a Honda dealership and ask them what you should do.... are you pushing in the odometer reset button before you turn the car to the on position?
Old Jun 21, 2007 | 04:44 PM
Funnyfarm
It is the maint reqd light. Yes, we are pushing the reset before turning the car to on
We contacted 1 dealer who told us that there might be add'l maint required after 30,000, and that possibly there was another sequence needed to reset, but he didnt know what that sequence might be
Old Jun 21, 2007 | 06:52 PM
sir_nasty's Avatar
that's a new one to me.... All people have ever done that I know of is to push that in and hold it as they turned the car on. Have you tried holding it in for more like 30 seconds?
Old Jun 21, 2007 | 08:12 PM
tkundert2's Avatar
I just had to reset mine and I had to hold the button in for longer (it seemed) than 15 seconds. Did you hold it in until the lightdisappeared?
MikeMoss
Dec 3, 2011 08:04 AM
TJROCKSTAR
Feb 11, 2007 12:45 AM
ernie22golf
Mar 22, 2006 09:59 PM
ernie22golf
Feb 8, 2006 11:19 AM
bbradley
Feb 7, 2006 02:50 AM
