maintenence required light
Old Jul 15, 2007 | 01:13 AM
erdie721's Avatar
Default maintenence required light
Is there any way to check what it means when the "maitenence required" light turns from green to yellow in my 94 accord EX? I have the VTEC engine and a manual transmission.
Old Jul 15, 2007 | 07:01 AM
Chiovnidca's Avatar
Default RE: maintenence required light
Means it's almost time to service it. When it turns red it's time. Your owners manual should have a list of reccomended service items based on time and mileage.
Old Jul 15, 2007 | 09:28 PM
smaglik's Avatar
correct. how many miles are on it? i used to pick and choose from the dealer list as my 94 aged...i stopped following it closely at about 150k miles and only did what needed to be done.
Old Jul 15, 2007 | 09:36 PM
Mitsu Racer's Avatar
When the Check Engine light came on in my '00 Accord Coupe, I thought I was just a little late getting it serviced. But the next thing I knew, I was dropping in a new tranny.... >_>
Old Jul 15, 2007 | 10:11 PM
smaglik's Avatar
that's a special case. the tranny's were *** in the 6th gen
Old Jul 17, 2007 | 12:00 PM
00AccordLX5spd's Avatar
Registered User
Check Engine Light and "Maintenance Required" light in 98-02 Accords/indicator in 94-97 Accords are two totally different things. The maintenance required indicator or light comes on automatically after the car has gone a certain number of miles, regardless of the service that has been done. You still have to reset it yourself. Check Engine light means the car's computer has found something wrong......well "wrong" is kind of a strong word. I guess I should say the computer has detected something that is abnormal.
Old Jul 17, 2007 | 12:05 PM
smaglik's Avatar
isnt there an SES light in the 5th gen? i cant recall cause mine never came on in the 9 yrs i owned it.
Old Jul 17, 2007 | 12:50 PM
Trav20's Avatar
Question how would I resetthe maint required lighton an 2004 ex coupe? I had it serviced but it won't turn off. It annoys me bc it blinks in yellow 4-5 times every time i turn on my car and keep thinkin something is wrong with my car...
Old Jul 17, 2007 | 01:07 PM
Registered User
If you can do it yourself it should tell you how in the Owner's manual. I would imagine you should be able to do it yourself so [sm=icon_rtfm.gif]
Haha! I always wanted to use that one!
Old Jul 17, 2007 | 01:09 PM
Registered User
Oh yeah...erdie721, to reset the "maintenance required" indicator on your year model, there is a slot right above the indicator on the instrument cluster. Stick your key in that slot and the indicator will go back to green
