Maybe just a tune-up?
I have a 98 4door, 5spd, 4cyl. She's got 255,000 miles and its starting to run a little rough. This weekend, I am going to replace the cat. converter b/c it's rattling and is really annoying. I am noticing an issue when accelerating. after about 4,000 rpm, my compression drops bad.
I am wanting to do a general tune-up (new spark plugs, wires, tranny fluid oil maybe a new fuel & air filters) Do you think this will help with the loss of power? Thanks for any feed back! Kurt |
Does the check engine light turn on while driving? Have you checked for error codes?
Have you done a compression test on the engine? A tuneup is a good idea. Use the NGK plugs recommended in the owner's manual. There is no external fuel filter that I am aware of on a 98. Air filter is a good idea. The distributor cap and rotor are probably more important the the spark plug wires. |
The check engine light was coming on then going off. I ran the numbers and it was for the cat.
Every once in a while, the car will turn off at highway speeds and then start back up... Fortunately, I have a family mechanic at the Honda dealership (my dad was a salesman there for 20+ years) I'l hand it over to him and have him fix the stuff, I'm just wondering what I should pick up at the auto parts store for the tune-up before droping off the car tomorrow. |
I would pick up the spark plugs and the air filter at a parts store.
Distributor cap and rotor from the Honda dealership. You can get these at the parts store, but I think Honda makes better ignition system parts. May pay $15 dollars more for them, but probably worth it. |
