Maybe just a tune-up?
Old Apr 15, 2011 | 12:55 PM
98accord5speed's Avatar
Default Maybe just a tune-up?
I have a 98 4door, 5spd, 4cyl. She's got 255,000 miles and its starting to run a little rough. This weekend, I am going to replace the cat. converter b/c it's rattling and is really annoying. I am noticing an issue when accelerating. after about 4,000 rpm, my compression drops bad.
I am wanting to do a general tune-up (new spark plugs, wires, tranny fluid oil maybe a new fuel & air filters) Do you think this will help with the loss of power?
Thanks for any feed back!
Kurt
Old Apr 15, 2011 | 01:12 PM
Does the check engine light turn on while driving? Have you checked for error codes?
Have you done a compression test on the engine?
A tuneup is a good idea. Use the NGK plugs recommended in the owner's manual. There is no external fuel filter that I am aware of on a 98. Air filter is a good idea. The distributor cap and rotor are probably more important the the spark plug wires.
Old Apr 15, 2011 | 01:40 PM
The check engine light was coming on then going off. I ran the numbers and it was for the cat.
Every once in a while, the car will turn off at highway speeds and then start back up...
Fortunately, I have a family mechanic at the Honda dealership (my dad was a salesman there for 20+ years) I'l hand it over to him and have him fix the stuff, I'm just wondering what I should pick up at the auto parts store for the tune-up before droping off the car tomorrow.
Old Apr 15, 2011 | 03:54 PM
I would pick up the spark plugs and the air filter at a parts store.
Distributor cap and rotor from the Honda dealership. You can get these at the parts store, but I think Honda makes better ignition system parts. May pay $15 dollars more for them, but probably worth it.
HondaAccord96LX
Aug 10, 2010 08:03 AM
white2abbit
Jul 5, 2007 03:02 PM
Markus26
Aug 20, 2006 05:05 PM
9JordonFlex9
Aug 14, 2006 04:26 AM
tnplaya615
Jul 7, 2006 12:38 AM
